*endnotehistorystate
Defines the end of a history state.
*endnotehistorystate name
HyperMesh Tcl Modify Command
Defines the end of a history state. Must be preceded by a call to *startnotehistorystate with the same name value.
This is used to group a set of commands into a single undo/redo operation. All commands that appear within the start/end block must be supported for undo/redo.
- name
- The name of the history state. If the name contains spaces, it must be enclosed in curly braces or quotes.
To execute an element remesh operation on two selections of elements, but consider them as
a single history
operation:
*startnotehistorystate {Remesh two element selections}
*setedgedensitylinkwithaspectratio 0
*setoption element_order=1
*setusefeatures 3
*createmark elements 1 1-100
*defaultremeshelems 1 1 2 2 1 1 1 1 0 0 0 0 2 30
*createmark elements 1 1-1-200
*defaultremeshelems 1 2 2 2 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
*endnotehistorystate {Remesh two element selections}Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
