*ME_ModuleOccurrencesDeleteByMark
Deletes a mark of modules.
*ME_ModuleOccurrencesDeleteByMark mark_id
HyperMesh Tcl Modify Command
The module must be an occurrence and cannot be root.
- mark_id
- The ID of the mark containing the modules to delete. Valid values are 1 and 2.
Examples
To delete modules 1-10:
*createmark modules 1 1-10
*ME_ModuleOccurrencesDeleteByMark 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
