*normalsadjust2
Adjusts the normals of 2D and 3D elements.
*normalsadjust2 entity_type mark_id mode orientation_element size display vector_id ?feature_angle?
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to adjust normals for. Valid values are elements, surfaces, and components.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- mode
- The orientation mode. For elements belonging to FE-surfaces, though, each connected
section is limited by surface borders and 'dominant normal direction' is calculated for
each FE-surface separately.
- 0 - For each connected section, adjust the normals for all elements in that section to be consistent with the 'dominant normal direction' already existing within that section. orientation_element and vector_id are ignored and can be 0.
- 1 - For each connected section, the entity in the section with its normal 'most parallel' to the orientation_element is found. All other elements in the section are adjusted to be consistent with this element. orientation_element must be a valid selection and vector_id is ignored and can be 0.
- 2 - Selected elements that are associated to surfaces are adjusted to match the normal of their surfaces. This is a no-op, but not an error, for elements not associated to a surface. orientation_element and vector_id are ignored and can be 0.
- 3 - For each connected section, the elements in the section are adjusted to be consistent with the specified vector direction. vector_id must be a valid selection and orientation_element is ignored and can be 0.
- 4 - For each connected section, adjust the normals for all elements in that section to be consistent with the 'dominant normal direction' already existing within that section, with the sections defined based on the specified feature_angle. orientation_elementand vector_id are ignored and can be 0.
- orientation_element
- The ID of the orientation element.
- size
- This argument is deprecated and should be always set to zero.
- display
- vector_id
- If mode is 3, this is the temporary vector ID created using *createvector. This should always be set to 1.
- ?feature_angle?
- If mode is 4, this is the feature angle to use to define the connected sections. This is ignored and not required otherwise.
To adjust the normals for elements 1-10 based on element
100:
*createmark elems 1 1-10
*normalsadjust2 elems 1 100 0 0 1To adjust the normals for all surfaces with feature angle 15
degrees:
*createmark surfs 1 all
*normalsadjust2 surfs 4 0 0 0 0 15Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
2017.1 - Added a new value of 4 for mode and a new optional argument feature_angle to support the auto adjustment of element normals, with the connected selection adjusted based on the feature angle.
2023 - Added support for FE surfaces and deprecated arguments size and display.
