*beamsectionupdateshellpartname
Renames a HyperBeam shell section part.
*beamsectionupdateshellpartname beam_sect_id part_index new_name
HyperMesh Tcl Modify Command
- beam_sect_id
- The ID of the shell beam section to update.
- part_index
- The index of the part to rename for that shell section, starting from 0.
- new_name
- The new name of the part.
Examples
To rename the part with index 3 for shell beamsection ID 100 to
"edge4":
*beamsectionupdateshellpartname 100 3 edge4Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-130
