*hf_setpartcomponent
Sets the specified component like the die module main part.
*hf_setpartcomponent entity_type mark_id
HyperMesh Tcl Modify Command
This command sets the specified component like the die module main part.
- entity_type
- The entity type. Must be set to comps.
- mark id
- The mark ID containing the component. Valid values are 1 and 2.
To set component ID 22 like the die module main
part:
*createmark comps 1 22
*hf_setpartcomponent comps 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
