*CE_ConnectorLineCombine
Combines multiple line connectors to a single line connector.
*CE_ConnectorLineCombine mark_id entity_type entity_mark_id entity_list_id ce_style num_links link_entity_type link_mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
Combines multiple line connectors to a single line connector. In addition, the internal lines (within the connectors) are merged into a single internal line.
- mark_id
- The ID of the mark of connectors. Valid values are 1 and 2.
- entity_type
- The entity type that specifies the location to create connectors. Valid values are lines.
- entity_mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2. If specified, set entity_list_id as 1.
- entity_list_id
- The ID of the list containing the entities. Valid values are 1 and 2. If specified, set entity_mark_id as 0.
- ce_style
- The style of connectors to create. Valid values are apply_mass, area, bolt, seam, and spot.
- num_links
- The number of links to use.
- link_entity_type
- The type of entity to create links for. Valid values are:
- link_mark_id
- The ID of the mark of link entities. Valid values are 1 and 2.
- string_array
- The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To combine spot line connectors 1 and 2 , lines 3 and 4, and components links 1, 2, 3 and 4
with combine_smooth
option:
*createmark connectors 1 1 2
*createmark lines 1 3 4
*createmark comps 2 3 4
*createstringarray 9 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=99.0" "line_density=0" "line_spacing=5.000000" "line_offset=0.000000" "line_combine_option=combine_smooth"
*CE_ConnectorLineCombine 1 lines 1 1 spot 2 comps 2 1 9Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
