*segmentsetremoveelems
Removes elements from a segment set.
*segmentsetremoveelems name mark_id
HyperMesh Tcl Modify Command
Removes elements from a segment set. If all elements are removed, the empty segment set still exists.
- name
- The name of the segment set to update.
- mark_id
- The ID of the mark containing the elements to remove. Valid values are 1 and 2.
Examples
To remove elements 100 and 101 from the segment set
"test":
*createmark elems 1 100 101
*segmentsetremoveelems "test" 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
