*triangle_clean_up
Fixes sliver/bad quality elements which fail the user-defined aspect ratio.
*triangle_clean_up entity_type mark_id criteria_string
HyperMesh Tcl Modify Command
- entity_type
- The type of input entity. Valid values are elems and comps.
- mark_id
- The ID of the mark of input entities. Valid values are 1 and 2.
- criteria_string
- There are two possible criteria that can be included in the string:
Examples
To correct all elements failing aspect ratio of 8:
*createmark components 1 "all"
*triangle_clean_up components 1 "aspect=8 height=3"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
