*createentitypanel
Allows you to interactively select a single entity
*createentitypanel entity_type message
HyperMesh Tcl Modify Command
This command provides you with a selector widget that is used to select a single entity. The entity selected is then retrieved using the command hm_info lastselectedentity entity_type.
If multiple entity selection is required, use *createmarkpanel.
- entity_type
- The type of entity to select.
- message
- The message to display to the user in the message bar.
Examples
To prompt you to select a single coordinate
system:
*createentitypanel systs "Select system"
if {[hm_info lastselectedentity systs] == 0} {
hm_errormessage "No system selected"
}Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
