*updatepositions
Reorganize entities in case of an addition, removal, or deletion of transformations, or a change in transformation order operations.
*updatepositions mark_id
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the position entities to refresh.
Examples
To update all positions in the model:
*createmark positions 1 all
*updatepositions 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
