*elementqualitysetup_new
Prepares a mark of elements for use within the interactive element cleanup tool.
*elementqualitysetup_new mark_id
HyperMesh Tcl Modify Command
This function interacts closely with the other *elementquality commands, and cannot function separately from them. It must be accompanied by a corresponding *elementqualityshutdown command.
- mark_id
- The mark ID containing the elements to be modified. Valid values are 1 and 2.
*createmark elements 1 10 11 12 13 14 15 16
*elementqualitysetup_new 1
<<various *elementquality commands>>
*elementqualityshutdown 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
