*reverseview
Reverses the display with respect to a view saved using *saveviewmask.
*reverseview name entity_type_id
HyperMesh Tcl Modify Command
- name
- The name of the view to reverse.
- entity_type_id
- The entity type ID to reverse.
Examples
Reverse the comps (entity type ID 3) in view
View2:
*reverseview View2 3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
