*adaptive_wrapper_end
Terminates the adaptive wrap mesher.
HyperMesh Tcl Modify Command
Terminates the adaptive wrap mesher and clears the temporary data populated during adaptive wrap mesh generation.
This command must be called after *adaptive_wrapper_init.
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
# Define features
*clearmark elements 1
*adaptive_wrapper_set_features 1 1 30 1 1
#Set various meshing and refinement parameters
*createstringarray 7 "LeakCheckNodes: 20 24 19" "GapPatchTolerance: 3.0" "HolePatchTolerance: 10.0" "RefineByBoxCompIds: 4 5 6" "RefineByNodeCurvature: 1" "RefineByFeatureProximity: 0" "RefineByAllElemSize: 1"
*adaptive_wrapper_set_params 10 0.1 1 7
#Proximity options
eval *createstringarray 3 "WithinGroup: 0.5 1 3 10 12 13" "WithinGroup: 1.5 3 9 20" "AcrossGroup: 0.5 3 10 12 13 4 9 8 7 19"
*adaptive_wrapper_proximity_params 1 0.2 1 3
#Build skeletal octree structure
*adaptive_wrapper_build
#Generate mesh
*createstringarray 2 "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0 1 2
#End of wrapper mesh
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
