*redohistorystate
Redoes one or more history states.
*redohistorystate count
HyperMesh Tcl Modify Command
- count
- The number of history states to redo.
To redo two history states:
*redohistorystate 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
