*fill_fe_holes_lines
Fills FE holes from a line selection defining the holes.
*fill_fe_holes_lines mark_id max_width string_array number_of_strings
HyperMesh Tcl Modify Command
longDescription
- mark_id
- The ID of the mark containing the lines on the hole boundary.
- max_width
- Maximum allowed hole width.
- string_array
- The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To fill the holes defined by the closed lines 1-5, using a max width of 20.5, remeshing
filled elements, and creating the elements in the adjacent
components:
*createmark lines 1 1-5
*createstringarray 3 "Remesh: 1" "AdjacentComp: 1" "DefineMaxWidth: 1"
*fill_fe_holes_lines 1 20.5 1 3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
