*createfmvss201u_createpoints
Creates a single, selected type of impact points on the upper interior of a vehicle.
*createfmvss201u_createpoints pointtype=<value> ?option1=<value1>? ?option2=<value2>? … ?optionN=<valueN>?
HyperMesh Tcl Modify Command
This command creates a selected type of marking lines and impact points on the upper interior parts of a vehicle. Must be used after the *createfmvss201u_start command or otherwise will return an error. After all the required points are created, *createfmvss201u_end must be called for cleanup.
- ap1=<value>, ap2=<value>, ap3=<value>, bp1=<value>, bp2=<value>, bp3=<value>, bp4=<value>, op1=<value>, op2=<value>, rp1=<value>, rp2=<value>, fh1=<value>, fh2=<value>, rh1=<value>, sr1=<value>, sr2h=<value>, sr2v=<value>, sr3=<value>
- Needs to be set to 1 if the design point with the same name is to be created, 0 otherwise.
- apbool=<value>
- Needs to be set to 1 if design points are to be created on A Pillar, 0 otherwise.
- apillarpartsids={id1 id2 … idN}
- The list of component IDs which make up the A pillar of the vehicle on the selected side.
- bp2pointid=<value>
- The node ID of the node where user wants to mark BP2 point.
- bpbool=<value>
- Needs to be set to 1 if design points are to be created on B Pillar, 0 otherwise.
- bphighestpointid=<value>
- The node ID of the highest point on the door opening forward to the B Piller. Used in marking B pillar points.
- bpillarpartsids={id1 id2 … idN}
- The list of component IDs of the B pillar of the vehicle on the selected side.
- bplowestpointid=<value>
- The node ID of the lowest point on the door opening forward to the B Piller. Used in marking B pillar points.
- bpn1pointid=<value>
- The top node ID on the center line of the B Piller. Used in marking B pillar points.
- bpn2pointid=<value>
- The bottom node ID on the center line of the B Piller. Used in marking B pillar points.
- fhbool=<value>
- Needs to be set to 1 if design points are to be created on Front Header, 0 otherwise.
- fhsunroofids=<value>
- The component IDs of the sunroof if sunroof parts are present. Used in marking FH2 point.
- interiorroofpartsids={id1 id2 … idN}
- The list of component IDs which make up the Interior roof of the vehicle. This is used for the marking of the upper roof zone.
- ippointid=<value>
- The node ID of the highest point on Instrument panel. Used in marking AP3 point.
- op1pointid=<value>
- The node ID of the node where user wants to mark OP1 point.
- opanchorage=<value>
- 0 - OP1 point is marked automatically.
- opbool=<value>
- Needs to be set to 1 if design points are to be created on O Pillar, 0 otherwise.
- ophighestpointid=<value>
- The node ID of the highest point on the door opening forward to the O Piller. Used in marking O pillar points.
- opillarpartsids={id1 id2 … idN}
- The list of component IDs of the O pillar of the vehicle on the selected side.
- oplowestpointid=<value>
- The node ID of the lowest point on the door opening forward to the O Piller. Used in marking O pillar points.
- opn1pointid=<value>
- The top node ID on the centre line of the O Piller. Used in marking O pillar points.
- opn2pointid=<value>
- The bottom node ID on the centre line of the O Piller. Used in marking O pillar points.
- pointtype=<value>
- The type of design points to be marked.
- rhbool=<value>
- Needs to be set to 1 if design points are to be created on Rear Header, 0 otherwise.
- rp2pointid=<value>
- The node ID of the node where user wants to mark RP1 point.
- rpbool=<value>
- Needs to be set to 1 if design points are to be created on Rear Pillar, 0 otherwise.
- rpillarpartsids={id1 id2 … idN}
- The list of component IDs of the R pillar of the vehicle on the selected side.
- sr3pointid=<value>
- The node ID of the node where user wants to mark SR3 point.
- srbool=<value>
- Needs to be set to 1 if design points are to be created on Side Rail, 0 otherwise.
- urbool=<value>
- Needs to be set to 1 if design points are to be created on Upper roof Zone, 0 otherwise.
Examples
To mark A pillar design points, Upper roof zone and B pillar design
*createfmvss201u_start side=0 vehicledir=-1 method=0 seattraveldist=127.0 weatherstrippingoffset=0.0 wsoffset=0.0 sgrp={2000.000000,-400.000000,500.000000} sgrprear={2800.000000,-400.000000,500.000000} exteriorpartsids={10003,10006} interiorpartsids={10000,10004,10007,10008,10010,10011,10016,10017} windshieldpartsids={10001}
*createfmvss201u_createpoints pointtype=0 apillarpartsids={10010} ap1=1 ap2=1 ap3=1 apbool=1 ippointid=57354
*createfmvss201u_createpoints pointtype=1 interiorroofpartsids={10000,10016,10017} urbool=1
*createfmvss201u_createpoints pointtype=2 bpillarpartsids={10007} bp1=1 bp2=1 bp2pointid=52327 bp3=1 bp4=1 bpbool=1 bphighestpointid=73386 bplowestpointid=53637 bpn1pointid=52774 bpn2pointid=51988
*createfmvss201u_endErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
