*hwct_closelibrary
Closes a currently open library.
*hwct_closelibrary entity_type
HyperMesh Tcl Modify Command
- entity_type
- The type of connected library. Supported for parts and subsystems.
Examples
Close the currently connected subsystem library:
*hwct_closelibrary subsystems
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
2024 - Added parts to supported entity types.
