*ME_ModuleOccurrencesReparent
Move a list of module parts or part assemblies underneath another part assembly in the model hierarchy.
*ME_ModuleOccurrencesReparent child_ids parent_id ?options?
HyperMesh Tcl Modify Command
This is only allowed in cases where it does not break sub-assembly instancing.
- child_ids
- The IDs of the modules to move, space separated in quotes.
- parent_id
- The ID of the module part (if empty and convertible to a part assembly) or module part assembly to become the parent.
- ?options?
- List of input options, passed as a comma separated string enclosed in quotes. Valid
options are:
- matrix_mode=<mode>
- 0 - Retain the relative position of the child module (default). This may cause the part to translate if there are matrices stored at different levels in the hierarchy.
Place the module part assemblies 100, 101 and 102 under part assembly 8 in the hierarchy. No translation should take place since the parts positions are not changing relative to their parents.
*ME_ModuleOccurrencesReparent "100 101 102" 8 "matrix_mode=1"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
