*morphnodesmatrixdiffenvelope
Reorients the selected nodes by taking the difference between two matrices while morphing the affected elements.
*morphnodesmatrixdiffenvelope m_entity_type m_mark_id e_entity_type e_mark_id f_entity_type f_mark_id matrix_array matrix_length integ mbias fbias envelope undisplayed
HyperMesh Tcl Modify Command
This command will reorient the selected nodes by taking the difference between two matrices positioned with respect to the global coordinate system. For each node, the position relative to the initial matrix is found and then relocated to the same relative position with respect to the final matrix. The fixed nodes are held in place and the affected elements (or all unfixed nodes in the model if integ is 3, 6, or 7) are stretched according to the value of integ.
Temporary handles are created for all moving and fixed nodes to determine the stretching of the affected elements. If integ is 0, a general domain is temporarily created for the affected elements. If integ is 1, the domains currently in the model are used. If integ is 2, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements but the 2D domains are not partitioned. If integ is 3, then handle influences are applied using a spatial relationship rather than through a domain. If integ is 4, only the selected moving nodes are moved and all others are held fixed. If integ is 5, 1D, 2D, 3D, and edge domains are temporarily created for the affected elements and the 2D domains are partitioned. Any handles created due to partitioning are moved based on their distance from the moving and fixed nodes. If integ is 6, then handle influences are applied using the Kriging algorithm. If integ is 7, then handle influences extend only up to a given distance (if envelope is positive) or a given multiple of the applied perturbations (if envelope is negative) away from the moving nodes.
The bias factors function as they would for handles except that all moving nodes will have the mbias value and all fixed nodes will have the fbias value.
If integ is set to 3, 6, or 7, nodes on undisplayed elements and components can be morphed, fixed, or excluded depending on the value sent in for undisplayed.
- m_entity_type
- Must be set to nodes.
- m_mark_id
- Mark ID of moving nodes. Valid values are 1 and 2.
- e_entity_type
- Must be set to elems.
- e_mark_id
- Mark ID of affected elements. Valid values are 1 and 2.
- f_entity_type
- f_mark_id
- Mark ID of fixed nodes. Valid values are 1 and 2.
- matrix_array
- ID of array of doubles, created using *createdoublearray. This should be set to 1. This array defines two 4x4 matrices where the first matrix is at the final orientation and the second matrix is at the initial orientation. The matrices have the following format:
- matrix_length
- The length of matrix_array. Must be set to 32.
- integ
- 0 - Free edges (a single general domain)
- mbias
- Bias factor of moving nodes.
- fbias
- Bias factor of fixed nodes.
- envelope
- If positive, all nodes beyond the given distance away from the moving nodes will be fixed. If integ is set to 7, the distance given defines an envelope around the moving nodes within which the morphing of those nodes will linearly taper from fully matching the nearest moving node to zero at the edge of the envelope. If any fixed nodes are within the envelope they will also reduce the morphing of nearby nodes.
- undisplayed
- If integ is set to 3, 6, or 7, nodes which are not displayed can be affected by the morphing. This field can be used to determine how undisplayed nodes are handled:
Examples
*createmark nodes 1 11 12 13
*createmark elems 1 "all"
*createmark nodes 2 21 22 23
*createdoublearray 32 0.866 0.5 0 0 -0.5 0.866 0 0 0 0 1.0 0 1.8 2.6 3.5 1 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
*morphnodesmatrixdiffenvelope nodes 1 elems 1 nodes 2 1 1 1.0 1.0 0.0 0Errors
# Handle error
}Version History
2019
