*relativerotatedummyjoint
Rotates a dummy joint relative to its current location.
*relativerotatedummyjoint entities collectorId axis rotAngle parentChild
HyperMesh Tcl Modify Command
- entities
- The entity type. Currently, only components is supported.
- collectorId
- The id of the collector that is part of the parent/child system. The parent or child system itself will be rotated, depending on the parentChild toggle.
- axis
- The axis of the child that you want to rotate about.
- 0 X axis
- 1 Y axis
- 2 Z axis
- rotAngle
- The number of degrees to rotate about the axis.
- parentChild
- If set to 0, the child is rotated about its own axis. If set to 1, the parent is rotated about the child’s axis.
To rotate a joint around the child’s X axis by 25 degrees specifying the collector that
contains the system for the elbow
joint:
*relativerotatedummyjoint components 1 0 25 0 Errors
None.
