*animationframenext
Advances to the next animation frame.
*animationframenext
HyperMesh Tcl Modify Command
This command advances to the next animation frame.
Examples
To advance the animation to the next frame:
*animationframenextErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
