*sethistorylimit
Sets the maximum number of history states to allow.
*sethistorylimit count
HyperMesh Tcl Modify Command
- count
- The number of history states to allow.
- 0 - Disables all history recording, including potential legacy use cases.
- -1 - Indicates unlimited.
To set the maximum number of history steps to allow to 100:
*sethistorylimit 100
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
