*CE_AutoCreateMatingConnectors
Identifies the mating holes in selected parts and creates connectors.
*CE_AutoCreateMatingConnectors entity_type mark_id <option1>=<value1> <option2>=<value2> … <optionN>=<valueN>
HyperMesh Tcl Modify Command
Identifies the mating holes in selected components or parts and creates a connector at the specified locations of the mating holes.
- entity_type
- The input entity type. Valid values are components and parts.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- Allow_Hole_to_Tube=<value>
- Allows identifying tube hole mates. Valid values are 0 and 1.
- Allow_mismatched_shapes=<value>
- Allows identifying mismatched holes. Valid values are 0 and 1 (default).
- Allow_Self=<value>
- Allows identifying mating holes within the same part/component. Valid values are 0 and 1.
- Center_CE=<value>
- Allows the connector to be created at the center of the two mating holes. Valid values are 0 and 1.
- Hole_Type=<value>
- The type of the hole to be identified as the mating hole.
- Lateral_Distance=<value>
- The lateral distance (default true).
- Lateral_Factor=<value>
- Option to consider max lateral factor. Supported values are true and false. Effective only if Lateral_Distance is set to false.
- Max_Angle=<value>
- The maximum lateral angle within which the mating holes should be identified.
- Max_Dia=<value>
- The maximum diameter of the hole considered for hole identification.
- Max_Distance=<value>
- The range within which the mating holes should be identified.
- Max_lateral_distance=<value>
- The maximum allowed lateral distance (default 1.0).
- Max_lateral_factor=<value>
- The maximum lateral factor (default 0).
- Min_Dia=<value>
- The minimum diameter of the hole considered for hole identification.
Examples
To identify mating holes and create connectors between the displayed parts at the
identified locations:
*createmark parts 1 displayed
*CE_AutoCreateMatingConnectors parts 1 Hole_Type=7 Max_Distance=10 Max_dia=20 Min_dia=0 Max_Angle=5 Max_lateral_distance=0.874886635 Max_lateral_factor=0 Allow_mismatched_shapes=1 Allow_Hole_to_Tube=0 Allow_Self=0 Lateral_Distance=1 Lateral_Factor=0 Center_CE=0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
