*CE_FE_CreateDCC
Creates all connector control default entities.
*CE_FE_CreateDCC reserved
HyperMesh Tcl Modify Command
- reserved
- Reserved for future use, must be set to 0.
Examples
To create all connector control default entities:
*CE_FE_CreateDCC 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
