*morphcreateresultsfile
Creates and loads a results file named autodv.animate from the selected shapes.
*morphcreateresultsfile entity_type mark_id
HyperMesh Tcl Modify Command
Creates and loads a results file named autodv.animate from the selected shapes. This file contains a simulation for each shape with a displacement data type and is located in the working directory.
- entity_type
- Must be set to shapes.
- mark_id
- The ID of the mark containing the shapes. Valid values are 1 and 2.
To create a results file for the shape shapes:
*createmark shapes 1 shape1
*morphcreateresultsfile shapes 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
