*activatetransformations
Apply or unapply all the transformations in the model.
*activatetransformations mark_id flag
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing all transformations in the model.
- flag
- 0 - Unapply
Examples
To apply all the transformations in the model:
*createmark positions 1 all
*activatetransformations 1 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
