*segmentsetaddfacesusingfacenumber
Adds faces of elements using a specific face number to a segment set.
*segmentsetaddfacesusingfacenumber name mark_id face_number reverse_normals element_id option
HyperMesh Tcl Modify Command
- name
- The name of the segment set to update.
- mark_id
- The ID of the mark containing the elements to add. Valid values are 1 and 2.
- face_number
- The face number of the element (starting from 0).
- reverse_normals
- Create segment set:
- element_id
- If non-zero, specifies the single element to use instead of mark_id. option must be set non-zero.
- option
- If non-zero, specifies to use element_id instead of mark_id.
Examples
To add elements 1 through 100 using face number 2 to segment set
"test":
*createmark elems 1 1-100
*segmentsetaddfacesusingfacenumber "test" 1 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
