*fetosurfs
Generates surfaces from shell elements.
*fetosurfs mark_id_2d mark_id_1d options complexity tolerance reserved
HyperMesh Tcl Modify Command
- mark_id_2d
- The mark ID that contains the input 2D shell elements, which are used to construct the surface.
- mark_id_1d (optional)
- The mark ID that contains edge/feature elements, which are used to split shell elements into separate surfaces.
- options
- Specifies options for creating the surfaces. Bit values are used and the value is
calculated as (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 +
64*Bit6).
- Bit0
- 0 - Use given tolerance to control accuracy.
- Bit1
- 0 - Do not attempt automatic shell splitting in cases where surface approximation could not be calculated for given tolerance and complexity limit.
- Bit2
- 0 - Ignore failure on some patches and calculate the remainder.
- Bit3
- 0 - Ignore sharp features unless specified by input feature edges.
- Bit4
- 0 - Ignore element component information.
- Bit5
- 0 - Do not associate nodes to created surfaces.
- Bit6
- 0 - Do not use automatic feature detection.
- complexity
- A number controlling the maximum complexity of a single surface patch. This sets the maximum number of control points for a surface.
- tolerance
- Geometry simplification tolerance. Defines the maximum distance between original and simplified geometries.
- reserved
- Reserved for future use. Must be set to 0.
To construct a surface from all quad4 elements, using a tolerance of 0.1, limiting the
number of control points to 900, no automatic shell splitting, stop on failures, split
surfaces by sharp features, split surfaces according to element components, associate nodes,
and no automatic feature detection (options = 1*0 + 2*0 + 4*1 + 8*1 + 16*1 + 32*1 +
64*0 =
60):
*createmark elems 1 "by config" quad4
*fetosurfs 1 0 60 900 0.1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
