*setelemparamscolors
Sets the color for all element quality parameters for elements violating the threshold.
*setelemparamscolors double_array number_of_doubles
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for all element quality parameters for elements violating the threshold.
- double_array
- The ID of the double array containing the color values for each quality parameter. Must always be set to 1.
- number_of_doubles
- Must currently be set to 12.
To set colors for all element quality parameters:
*createdoublearray 12 59 39 41 56 28 61 19 22 46 57 29 3
*setelemparamscolors 1 12
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
