*ME_ModuleExport
Exports the contents of a module to an ASCII export file based on an output template.
*ME_ModuleExport id recursive filename export_template string_array number_of_strings
HyperMesh Tcl Modify Command
- id
- The ID of the part or part assembly to export.
- recursive
- Specifies option for whether the module hierarchy should be traversed recursively to identify all of the entities to be exported.
- filename
- The full path and filename of the output file. Paths with spaces must be enclosed in quotes.
- export_template
- The full path and filename of the export template to be used. Paths with spaces must be enclosed in quotes.
- string_array
- The ID of the string array that contains the additional output parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray. The valid strings are documented as subtopics to *feoutputwithdata. Not all templates support all strings.
To output using the OptiStruct template, to a file named C:/model.fem for all entities in part with ID 10:
*ME_ModuleExport 10 0 "C:/model.fem" [hm_info -appinfo SPECIFIEDPATH TEMPLATES_DIR]/feoutput/optistruct/optistruct" 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
