*surfacecreatedraglinealongline
Create one or more surfaces by dragging one or more lines along a line.
*surfacecreatedraglinealongline lines_mark_id lines_list method options comp_mode ?node_id? ?refplane?
HyperMesh Tcl Modify Command
This command creates surface(s) by dragging section lines(s) along a drag line. Lines in the line list are combined into a single line L, called the drag line. The direction of the drag line is determined by choosing its start point, S, as the closest end of the line to the section line vertices.
node_id and refplane arguments are optional and determines how the input lines are transformed before drag.
The reconfiguration of the geometries before the drag is done as follows. Let P be the point referred by the node_id, N be the normal and B be the base point of the refplane and T be the tangent vector of drag line at S. First, section lines are translated by the direction vector PB. If Bit3 of the options is not set, then, the section lines are rotated by the rotation from vector N to vector T. Also, the drag line is translated by the direction vector SB. The drag is applied to along this line L. So, if P is selected on a section line, the new location of P is going to be at B. Moreover, if P is one of the vertex points of the section lines, one gets an exact geometric copy of the drag line at B, no matter which drag method is chosen. This is because, prior to drag, P is moved to B and B moves on drag line since it coincides with the start point of the drag line L.
If node_id is not given, it is chosen as the same point as S, the start of the drag line. This means, with the default value of node_id, the drag line is not transformed.
If the reference plane is not given, their default values are B at P and N=T. This means, with the default value of transformation plane, the section lines are not transformed prior to drag.
Note that, the location of P is not important if fixed frame method is chosen with no transformation plane, since each point on the section surface traces an exact geometric copy of the drag line in fixed frame method.
- lines_mark_id
- The mark ID containing the lines that you wish to drag.
- lines_list
- The list ID containing the lines that will be used to from the drag line.
- method
- Parameter specifying the method of how the drag is performed. Valid options are:
- options
- Flags that indicate different modes for the drag. Bit values are used and the value is
calculated as (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3).
- Bit0
- 0 - Drag along the direction of the drag line.
- Bit1
- 0 - Do not merge input lines. A surface is created for each input line.
- Bit2
- 0 - Use the ref_plane input.
- Bit3
- 0 - Use the whole ref_plane for transformation if it is given.
- comp_mode
- Parameter specifying how entities are organized into components:
- ?node_id? (optional)
- The ID of the node that is used as a reference point while determining how the surfaces are transformed prior to drag.
- ?ref_plane? (optional)
- When provided, its value must always be 1. It is used to determine the initial reference frame. This plane is created using the *createplane command.
Examples
*createmark lines 1 39 401 388
*createlist lines 1 37 25
*surfacecreatedraglinealongline 1 1 0 3 1*createmark lines 1 39 401 388
*createplane 1 1.0000 1.0000 1.0000 2678.0 -737.7 548.1
*surfacecreatedraglinealongline 1 1 0 3 1 12 1 The surfaces created will be in such a way that the new location of the point on which node 12 located, will be at the base point (2678.0 -737.7 548.1) of the reference plane.
# Handle error
}Version History
10.0
