*adaptive_wrapper_set_params
Assigns meshing parameters to the adaptive wrapper mesher.
*adaptive_wrapper_set_params max_elem_size min_elem_size string_array number_of_strings
HyperMesh Tcl Modify Command
Assigns meshing parameters to the adaptive wrapper mesher. Controls include refinement box, refinement options, hole patch, gap patch, leak check, min and max element size, etc.
This command must be called after *adaptive_wrapper_init and before *adaptive_wrapper_build.
- max_elem_size
- The maximum element size for adaptive wrap meshing.
- min_elem_size
- The minimum element size for adaptive wrap meshing.
- string_array
- The ID of the string array that contains the proximity control parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
# Define features
*clearmark elements 1
*adaptive_wrapper_set_features 1 1 30 1 1
#Set various meshing and refinement parameters
*createstringarray 7 "LeakCheckNodes: 20 24 19" "GapPatchTolerance: 3.0" "HolePatchTolerance: 10.0" "RefineByBoxCompIds: 4 5 6" "RefineByNodeCurvature: 1" "RefineByFeatureProximity: 0" "RefineByAllElemSize: 1"
*adaptive_wrapper_set_params 10 0.1 1 7
#Proximity options
eval *createstringarray 3 "WithinGroup: 0.5 1 3 10 12 13" "WithinGroup: 1.5 3 9 20" "AcrossGroup: 0.5 3 10 12 13 4 9 8 7 19"
*adaptive_wrapper_proximity_params 1 0.2 1 3
#Build skeletal octree structure
#Generate mesh
*createstringarray 2 "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0 1 2
#End of wrapper mesh
*adaptive_wrapper_end
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
