*setoffsetconflictoptionmessage
Set the message option when there is offset conflict during drag-and-drop.
*setoffsetconflictoptionmessage mode
HyperMesh Tcl Modify Command
- mode
- 0 - Do not keep the user input for all following drag-and-drop operations
Examples
To keep the user input for all following drag-and-drop operations:
*setoffsetconflictoptionmessage 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
