*CE_ReverseSigPoints
Reverses the direction of a line connector.
*CE_ReverseSigPoints connector_id
HyperMesh Tcl Modify Command
- connector_id
- The ID of the connector.
Examples
To reverse the direction of line connector ID 1:
*CE_ReverseSigPoints 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
