*elementtestaspect
Tests 2D and 3D elements using the aspect element quality check.
*elementtestaspect entity_type mark_id aspect output_mark_id dimension contour title
HyperMesh Tcl Modify Command
- entity_type
- The entity types to be checked. Only elements are supported.
- mark_id
- The mark ID containing the elements to test. Valid values are 1 and 2.
- aspect
- The value to use as a threshold beyond which elements should be considered to have failed the test.
- dimension
- The option of whether to measure 2D or 3D elements:
- 2 - Measure 2D elements.
- 4 - Measure 3D elements.
- output_mark_id
- The mark ID where the failed elements will be placed. Valid values are 1 and 2.
- contour
- Flag that determines how the results are presented. Valid values are:
- 0 - Display the results of the test normally.
- 1 - Display the elements color coded by their ratings.
- 2 - Build a histogram showing the distribution of ratings.
- title
- The title to label the curve in the histogram. Only required, if contour is 2.
To test all displayed 3D elements for an aspect of
5.0:
*createmark elems 1 "displayed"
*elementtestaspect elems 1 5.0 0 4 0 ""To test all displayed 2D elements for an aspect of
6.0:
*elementtestaspect elems 1 6.0 0 2 0 ""Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
