*set_flags_for_2dmesh_context
Preserves selection topology used by 2D meshing.
*set_flags_for_2dmesh_context <pption1>=<value1> ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Preserves selection topology used by 2D meshing. This is useful while doing 2D meshing iteratively on fixed selections, but modifying edge and face settings iteratively.
- automatic
- 0 - Does not delete FE for failed surface selection and continues to retain previous topology
- interactive
- 0 - Clear the last preserved topology information.
Examples
To set interactive meshing option to
1:
*set_flags_for_2dmesh_context interactive=1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
