*setqualitythresholdcolor
Sets the color for a specified element quality index range.
*setqualitythresholdcolor range_id color
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for a specified element quality index range.
- range_id
- Specifies the element quality index range to update. Valid values are:
- 0 - Ideal (ideal ≤ QI < good)
- 1 - Good (good ≤ QI < warn)
- 2 - Warn (warn ≤ QI < fail)
- 3 - Fail (fail ≤ QI < worst)
- 4 - Worst (worst ≤ QI)
- color
- The color to use. Valid values are 1 through 64.
To assign the color for the warn range to brown:
*setqualitythresholdcolor 2 28
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
