*ME_ModuleOccurrencesPurge
Empty the contents of multiple module parts or part assemblies.
*ME_ModuleOccurrencesPurge ids ?options?
HyperMesh Tcl Modify Command
- ids
- The IDs of the modules to purge, within quotes.
- ?options?
- List of input options, passed as a comma separated string enclosed in quotes. Valid
options are:
- excluded_entity_types=type1 type2 … typeN
- A space separated list of module entity types to not remove.
- reset_representation=<flag>
- 0 - Keep representation reference information.
- resursive=<flag>
- 0 - Purge only the local module’s contents. Do not touch the child module’s contents (in the case of a part assembly).
Purge part assemblies 168, 169, 170 and any of their child parts or part assemblies, removing all of their contents except for property and material entities. Remove representation reference information.:
*ME_ModuleOccurrencesPurge "168 169 170" "recursive=1, excluded_entity_types=props mats, reset_representation=1"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
