*beamsectionsetdataroot
Updates the root data for a beam section.
*beamsectionsetdataroot beam_sect_id collector_id solver beam_config line_color fill_color flags torsion_factor warping_factor orient_vector1 orient_vector2 orient_origin1 orient_origin2
HyperMesh Tcl Modify Command
Updating a beam section requires two commands, of which this is the first. This command updates the root data for a beam section and will also clear all other beam section data. Thus, this command should be followed by *beamsectionsetdatastandard, *beamsectionsetdatashell, *beamsectionsetdatasolid, or *beamsectionsetdatageneric depending on the beam_config selected. Beam section data cannot be updated piecemeal with this command; all data must be known for the beam and sent in as arguments.
- beam_sect_id
- The ID of the beam section to update.
- collector_id
- The ID of the beam section collector to update.
- solver
- Integer indicating the solver the section is for. Valid values are:
- beam_config
- Basic configuration of the beam section. Valid values are:
- line_color
- Currently unused. Must be set to 7.
- fill_color
- Currently unused. Must be set to 1.
- torsion_factor
- warping_factor
- flags
- Currently unused. Must be set to 0.
- orient_vector1
- orient_vector2
- orient_origin1
- orient_origin2
Examples
*beamsectionsetdataroot 1 1 0 2 7 1 0 1.0 1.0 0 0 0 0*beamsectionsetdataroot 1 1 0 2 7 1 0 1.0 1.0 0 0 0 0
*createdoublearray 12 6 6 6 0.5 0.5 0.5 4 4 4 1 1 1
*beamsectionsetdatastandard 1 12 1 4 0 HMHatErrors
# Handle error
}Version History
11.0.120
