*beamsectioncreatestandardsolver
Creates a standard solver-specific HyperBeam section.
*beamsectioncreatestandardsolver type solver type_name orient
HyperMesh Tcl Modify Command
Creates a standard solver-specific HyperBeam section. For a list of values that are supported by each solver, see the topics in the See Also section.
- type
- Integer indicating the type of section to create. Each solver has a number of available sections.
- solver
- Integer indicating the solver the section is being created for. Valid values are:
- type_name
- Name indicating the type of section to create. Each type can have multiple available section names.
- orient
- Flag indicating the orientation of the section:
Examples
To create a standard HyperBeam T-section having a 0 degree
orientation:
*beamsectioncreatestandardsolver 1 12 I 0To create a standard OptiStruct T-section having a 0 degree
orientation:
*beamsectioncreatestandardsolver 15 0 HMTSec 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
