*midmesh_inspect_init
Initializes the midmesh inspection module.
*midmesh_inspect_init SourceEntityType=<value> SourceMark=<value> TargetEntityType=<value> TargetMark=<value> <option5>=<value5> ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Initializes the midmesh inspection module. This must precede any calls to other *midmesh_inspect_* APIs, and must be followed by a call to *midmesh_inspect_end.
This tool detects problem clusters in midmeshes as follows:
- Nodes off middle
- Nodes off solid sides
- Nodes out of solid
- Element edges off of solid sides
- Element centers off middle
- SourceEntityType=<value>
- The source entity type, which must define the solid. Valid values are components, elements, solids, and surfaces. This is a mandatory option.
- SourceMark=<value>
- The ID of mark of source entities. Valid values are 1 and 2. This is a mandatory option.
- TargetEntityType=<value>
- The target entity type defining the midmesh. Valid values are components and elements. This is a mandatory option.
- TargetMark=<value>
- The ID of mark of target entities. Valid values are 1 and 2. This is a mandatory option.
At least one of the following options must also be provided.
- CheckMinElemSize=<value>
- Checks the minimum element size criteria while fixing the element center off mid and edge off solid edge problems. Valid values are 1 and 2.
- MinEdgeOffEdgeDeviation=<value>
- Detects element edges off solid sides with its value as minimum deviation. Valid values are > 0.0.
- MinElemCenterOffMidDeviation=<value>
- Detects element centers off middle with its value as minimum deviation. Valid values are > 0.0.
- MinNodeOffMidDeviation=<value>
- Detects nodes off middle with its value as minimum deviation. Valid values are > 0.0.
- MinNodeOffSolidEdgeDeviation=<value>
- Detects nodes off solid sides with its value as minimum deviation. Valid values are > 0.0.
- MinNodeOutOfSolidDeviation=<value>
- Detects nodes out of solid with its value as minimum deviation. Valid values are > 0.0.
Examples
To detect all problem
types:
*createmark components 1 "shell"
*createmark components 2 "MidmeshEdges" "Mid"
*midmesh_inspect_init SourceEntityType=components SourceMark=1 TargetEntityType=components TargetMark=2 MinNodeOffMidDeviation=0.2 MinNodeOffSolidEdgeDeviation=0.2 MinNodeOutOfSolidDeviation=0.2 MinEdgeOffEdgeDeviation=0.2 MinElemCenterOffMidDeviation=0.3 CheckMinElemSize=1
*midmesh_inspect_endTo detect and correct nodes off mid, delete empty sets, and shut down the inspect
module:
*midmesh_inspect_fix_problems nodes 2 ProblemType=NodeOffMid SmoothClusters=1 SmoothMethod=Auto
*midmesh_inspect_delete_sets 2
*midmesh_inspect_endErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
