*morphmapedgestonodelistoffset
Maps selected morph volume edges to the specified node list.
*morphmapedgestonodelistoffset user_mark_id node_list_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command will fit (evenly distribute) or project (along vector or normal) the handles on the marked morph volume edges to a line calculated from the specified points.
- user_mark_id
- The ID of the user mark containing the morph edges. Valid values are 0-3.
- node_list_id
- The ID of the list containing the input nodes. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry links
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- number_of_mid_handles
- -1 - Do not change the handles on the edges
- offset
- The distance to offset nodes from the target. Not used if project is 2.
Examples
To map edges on mark 0 offset by 1.2 from a node list along a vector leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createlist nodes 1
*createvector 1 1.0 0.0 0.0
*morphmapedgestonodelistoffset 0 1 1 1 0 1 -1 1.2
To map edges on mark 1 to a node list along the node list normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*createlist nodes 1
*morphmapedgestonodelistoffset 1 1 1 1 1 1 3 0.0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
