*morphupdateparameterstring
Updates string morphing parameters.
*morphupdateparameterstring parameter value
HyperMesh Tcl Modify Command
This command updates string morphing parameters.
- parameter
- The parameter of interest. Valid parameters are:
- value
- The new value of the parameter.
To update the name of the FEA simulation for plotting:
*morphupdateparameterstring iressimu "Cantilver loading"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
