*morphhandleprojectplaneoffset
Morphs a mesh by projecting selected handles on to the specified plane.
*morphhandleprojectplaneoffset h_entity_type h_mark_id p_entity_type p_mark_id plane nproj proj sym con offset
HyperMesh Tcl Modify Command
This command moves each of the selected handles on to the defined plane along a direction defined by the projection type. Applying symmetry links, constraints, and an offset are optional. All domains influenced by the selected handles will be morphed accordingly.
If nproj is set to 2, 5, or 6, the shell elements on the mark will be used to determine the projection direction for the handles. If no elements are on the mark then all shell elements will be used to determine the projection directions.
If symmetry is specified, handles linked through symmetry to those selected will be moved in a way that mirrors the selected handles which may or may not move them to the specified plane.
Constraints may move the perturbed handles off of the specified plane after the handles are moved to the plane.
The offset can be set as an absolute amount, an amount added to half the thickness of the shells touching the handles, or an amount multiplied by half the thickness of the shells touching the handles.
- h_entity_type
- Must be set to handles.
- h_mark_id
- The ID of the mark containing the handles. Valid values are 1 and 2.
- p_entity_type
- Must be set to elements.
- p_mark_id
- The ID of the mark containing the normal elements. Valid values are 1 and 2.
- plane
- The ID of the temporary target plane.
- nproj
- 0 - Project along vector proj
- proj
- The ID of the temporary projection vector.
- sym
- 0 - Ignore symmetry links
- con
- 0 - Ignore constraints
- offset
- The distance the handles will be offset from line (or added to or multiplied by half the thickness of the shells touching the handles).
Examples
To project handles to a line along a plane:
*createmark handles 1 "all"
*createmark elems 1
*createplane 1 1.0 0.0 0.0 1.0 0.0 0.0
*createvector 1 1.0 0.0 0.0
*morphhandleprojectplaneoffset handles 1 elems 1 1 1 0 1 1 1 0.0
TTo project handles to a node list normal to the plane:
*createmark elems 1
*morphhandleprojectplaneoffset handles 1 elems 1 1 1 1 1 1 1 0.0
To project handles to a plane normal to the elements and offset by the 1.5x the thickness:
*createmark elems 1 1 2 3 4 5 6
*morphhandleprojectplaneoffset handles 1 elems 1 1 1 22 1 1 1 1.5
# Handle error
}Version History
2022.3
