*hf_ResetDFRibs
Reset the ribs attribute.
*hf_ResetDFRibs int_flag
HyperMesh Tcl Modify Command
This command resets the rib attribute. All the ribs that you modify, dragging the latitude
lines, are checked with two attribute:
- fixed
- drag
- int_flag
- Integer dummy value. Should always be set to 0.
To reset all the rib attributes:
*hf_ResetDFRibs 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
