*mechcontructfromedi
Creates objects needed for solving enabled mechanisms.
*mechcontructfromedi mode param
HyperMesh Tcl Modify Command
Creates objects needed for solving enabled mechanisms, such as applying positions or moving bodies.
The mechanism must have the enabled flag set to true for this to be possible.
- mode
- The mode for mechanism operations:
- position
- The position ID to use when mode is 2.
Examples
To setup mechanism with ID 1:
*mechcontructfromedi 0 0
To apply position with ID 3 on mechanism with ID 1:
*mechcontructfromedi 2 3
*mechapplyediposition 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
