*CE_ConnectorAreaRebuild
Rebuilds the area connector mesh patch.
*CE_ConnectorAreaRebuild ce_mark_id elementsize elem_type ?param1? ?param2?
HyperMesh Tcl Modify Command
- ce_mark_id
- The ID of the mark containing the area connectors for which the area patch will be rebuilt.
- elementsize
- The element size for the mesh rebuild (default 10.0).
- elem_type
- The element type for the mesh rebuild. Valid values are Quad, Trias, Mixed, and R-trias.
- param1
- Reserved for future development.
- param2
Examples
To rebuild area connectors ID 1, 3, and 5 with element size 5.0 and element type
quad:
*createmark connectors 1 1 3 5
*CE_ConnectorAreaRebuild 1 5.0 Quad 0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
