*CE_ConnectorSpotTrim
Trims/splits spot line connectors using nodes.
*CE_ConnectorSpotTrim mark_id node_mark_id tolerance snap mode
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of connectors. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark of nodes. Valid values are 1 and 2.
- tolerance
- The tolerance value used to snap the nodes to the point of spot connectors when snap is 1.
- snap
- 0 - Do not snap nodes to spot connectors
- mode
- 0 - Split
Examples
To split spot connector 101 using node 1001:
*createmark connectors 1 101
*createmark nodes 1 1001
*CE_ConnectorSpotTrim 1 1 0.5 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
