*stackdisplay
Displays the stack direction of selected entities.
*stackdisplay entity_type mark_id size
HyperMesh Tcl Modify Command
Displays the stack direction of selected entities. Currently only supported for Abaqus continuum shell elements.
- entity_type
- The type of entity to display. Valid values are elements and components.
- mark_id
- The ID of the mark containing the entities to display. Valid values are 1 and 2.
- size
- The size in model units of the stack display.
To display the stack direction of elements 1-10 using a size of 10.0:
*createmark elems 1 1-10
*stackdisplay elems 1 10.0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.120
