*createnodesbetweenpositions
Creates nodes between two geometric positions in space.
*createnodesbetweenpositions x0 y0 z0 x1 y1 z1 count option systemid
HyperMesh Tcl Modify Command
- x0
- The x-coordinate of the start position.
- y0
- The y-coordinate of the start position.
- z0
- The z-coordinate of the start position.
- x1
- The x-coordinate of the end position.
- y1
- The y-coordinate of the end position.
- z1
- The z-coordinate of the end position.
- count
- The number of nodes to be created.
- option
- Determines if a node is created at the start and the end position.
- systemid
- The ID of the local system in which the positions are defined. Use 0 for the global system.
Examples
To create 7 nodes between positions (1.89, 8.83, 8.84) and (8.68, 1.82, 1.83) defined in the global system without creating nodes at the start and end position:
*createnodesbetweenpositions 1.89 8.83 8.84 8.68 1.82 1.82 7 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
